Code =P0420?
Old Feb 15, 2004 | 04:37 PM
MuffZ28's Avatar
Question Code =P0420?
I keep getting this code. My manual says it means "cata
Old Feb 15, 2004 | 04:50 PM
InjectedSS's Avatar
P0420 = Three Way Catalytic Converter (TWC) system low efficiency Bank 1
It means the cat on the left side of the car is clogged or some crap!
Actually I think it means that you should have bought an OBD1 Car
Old Feb 15, 2004 | 04:55 PM
MuffZ28's Avatar
Would that be the "coffee can"? when I looked underneath, it appeared to have only 1 cat, right after the Y.
Old Feb 15, 2004 | 05:35 PM
Super Slow '97's Avatar
Yes it is the can looking thing after the y. '96 is a duel cat car so the other one is in the vertical position next to the oil pan. I think this is the one you are having problems with as I think the driver side is bank one.
Old Feb 15, 2004 | 07:09 PM
MuffZ28's Avatar
Bank 1 is drivers side. I wasnt sure if that "thing" was a cat or not. Makes sense now. If I get rid of 1, should i do both? cant really afford to since i'm married w/ 4 children and am the only 1 working. Is there any negative effect from removing just 1?
Old Feb 15, 2004 | 07:29 PM
fastbird96's Avatar
If you remove them you will have to get O2 sims or the SES light will stay on.
lt1matt
Mar 21, 2015 07:35 PM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
