CM 612 Install height
Old Jul 9, 2008 | 11:24 PM
dubbsix's Avatar
Hey guys, can anyone give me information on the recommended install height for the combination motorsports 612 springs? I'll be running a cc503, with 1.6 pro mags.
Yes.. i've read the posts about the spring breakage.. just working on a budget here.
Thanks in advance!
Old Jul 10, 2008 | 03:36 AM
zcardriver22's Avatar
I think they are to be installed at the factory height but maybe somebody with more experience can help.
Old Jul 10, 2008 | 07:32 AM
1.80", I believe.
Old Jul 10, 2008 | 09:28 AM
dubbsix's Avatar
Hmm i just got a PM back saying about 1.780. Just wanting a concensus.
Old Jul 10, 2008 | 10:32 AM
truedualws6's Avatar
Need the spring rate and coil bind height to make a recommendation. The stock height is 1.78". Are they dimensionally (ID and OD) the same as stock springs?
Old Jul 10, 2008 | 10:56 AM
dubbsix's Avatar
I have no idea. I just know they are CM612'S
Old Jul 10, 2008 | 01:11 PM
PM from whom?
They posted on this very board 130 lbs @ 1.800".
Old Jul 10, 2008 | 03:11 PM
dubbsix's Avatar
From another member. I'll go with 130lbs @ 1.800"
Old Jul 10, 2008 | 07:01 PM
If they are a direct replacement for stock springs (which I think they are) you will be at 1.78" if your heads are stock. From what I have seen they are good for .600" lift, but I don't know if this includes a safety factor or if it's to coil bind. Worst case is .600" to coil bind, or a 1.20" solid height if the 1.80" number is correct.
The CC503 is .537"/.544" w/ 1.6 rockers and .503/.510" w/ 1.5s. Assuming 1.6 rockers you will have 1.78" - .544" = 1.236" which is only .036" to coil bind. This is a little tight for me. I like to see a minimum of .050" to coil bind. You really need to find the closed/solid height of the CM 612s to know for sure.
Old Jul 10, 2008 | 07:57 PM
They quoted the springs were 1.200" at full open. .0360" is about what a Hot cam kit has to coil bind (for whatever reason).
Old Jul 10, 2008 | 09:46 PM
dubbsix's Avatar
So does that mean the cam/rocker combo has too much lift for the springs?
Old Jul 10, 2008 | 10:20 PM
It depends on what you think is too much. You have gotten some opinions about it.
On a side note, I have been running the CC503 (though on a 114LSA) with 1.6 rockers and the CM 612 springs for over 5 years. Mine is a DD and I don't rev it to the moon all the time. And my comment about the Hot cam kit shows that with even less room to coil bind, people seem to be ok. I am not advocating less than .0500", just stating what some people are running.
Back when I put my cam and valvetrain together, I was not as schooled as I am now. I was told it would be ok and I trusted what was said (perhaps foolish on my part, but nothing bad has happened).
At this point, I would probably go with some beehives with a new valvetrain build.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
cmdeshon
Dec 12, 2014 10:51 PM
