Clutch and RPM question?
Old Nov 26, 2004 | 01:20 PM
Nick-LT1's Avatar
I am looking for a new car and i found a 95z with 6 speed cc306 and 1.6rr plus alot of bolt ons. The cars has a stock bottom end and he says at wot he shifts at 6500rpm is that to high for a stock bottom end? The revlimiter is set at 7000 rpm is that to high? Also i know nothing about 6 speeds but he says that 5 gear pops out but if you hold it in 5th and let the clutch out it is fine is that something to worry about?
Old Nov 26, 2004 | 02:11 PM
blaze309's Avatar
Re: Clutch and RPM question?
Im not sure if that's too much for the stock bottom end i shift around 5800 - 6000. I also don't have a cam and some cam's make power in the higher rpm's. i'll let some other guys answer on that one.
As far as the 5th gear popping out i think that's your syncro's <sp> not sure on how much they cost to fix.
Old Nov 27, 2004 | 01:15 AM
Nick-LT1's Avatar
Anyone?
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
mattszm6
Dec 14, 2014 07:09 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
Chrisdude
Aug 14, 2002 06:30 PM
