Clutch and RPM question?
I am looking for a new car and i found a 95z with 6 speed cc306 and 1.6rr plus alot of bolt ons. The cars has a stock bottom end and he says at wot he shifts at 6500rpm is that to high for a stock bottom end? The revlimiter is set at 7000 rpm is that to high? Also i know nothing about 6 speeds but he says that 5 gear pops out but if you hold it in 5th and let the clutch out it is fine is that something to worry about?
Re: Clutch and RPM question?
Im not sure if that's too much for the stock bottom end i shift around 5800 - 6000. I also don't have a cam and some cam's make power in the higher rpm's. i'll let some other guys answer on that one.
As far as the 5th gear popping out i think that's your syncro's <sp> not sure on how much they cost to fix.
Chrisdude
Aug 14, 2002 06:30 PM
