OBDI & Hooker Longtubes
Old Nov 25, 2004 | 07:39 PM
Red5.7's Avatar
I have done a lot of searching and can't find a straight answer. I am buying a used set of Hooker Longtubes (Taner's).
Anyway, the EGR and A.I.R. are going away - it is my understanding that no additional programming is required and no codes will be thrown on an OBDI car. The cat is obviously going as well....
It is to my understanding that I do not need new O2 sensors or simulators, but that I just need an extension. I believe I read somewhere that the driver O2 sensor will reach with the longtubes but the passenger side does need an extension.
Can anyone clear this up? Thanks!
Old Nov 26, 2004 | 07:04 PM
slopokrodrigez's Avatar
Re: OBDI & Hooker Longtubes
If the O2 bungs are in the headers, you are correct. Mine ended up in the collector and I needed 2 extensions.
Read this also. http://web.camaross.com/forums/showthread.php?t=315100
When you fire the things up, leave the O2's out and run it for a while. Then let it cool down and install them.
Dave
Old Nov 26, 2004 | 08:48 PM
Red5.7's Avatar
Dave
Yep, I read that thread and had it bookmarked, I just wasn't too clear on the 02 Extentions. Thanks you!
Old Nov 26, 2004 | 09:07 PM
NOMAD's Avatar
You will need both extensions and you will throw a code.
-Shannon
Old Nov 26, 2004 | 11:17 PM
zx1216's Avatar
It may throw a code but it will not throw a ses light if that is what you are woried about, although it did throw the ses light when i disconnected the egr selonoid so i left it plugged in untill i had it programed out.
Old Nov 27, 2004 | 02:04 AM
Red5.7's Avatar
Alright, thanks guys! Seems like I should be ok. I am fine with it throwing a code, but I really don't want it to throw the SES light incase there is something else that is actually wrong.
Old Nov 27, 2004 | 02:29 AM
Z95m6's Avatar
You may get an SES light that randomly appears everyonce in a while for the EGR.
tdigger9899
Sep 7, 2015 10:56 AM
97SSdude
Aug 21, 2015 09:36 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
jbc3
Jul 28, 2015 12:24 PM
