Clutch Recommendation
Old Aug 16, 2005 | 03:00 PM
RKHiPerformance's Avatar
The original clutch in my Dad's '96 Z28 finally gave up. I'm looking for suggestions for a suitable replacement.
The car's a regular driver that sees some spirited driving but will probably never see a sticky tire or a drag strip. I'm thinking about using the Ram HD set #88516 and re-surfacing the original flywheel. Any thoughts on this combination? What about the factory hydraulics? Any upgrades needed there?
Also, are there any LT1 specialists in the Mid-Atlantic area that could perform this install?
Thanks for the help,
Rick
Old Aug 16, 2005 | 03:28 PM
joeSS97's Avatar
Re: Clutch Recommendation
I would use the SLP clutch.JMO
Old Aug 16, 2005 | 03:31 PM
F-body Scotty's Avatar
Yeah, what he said...i just put in an SLP set up.....if im right they said its rated to handle upwards of 380 hp...if you havent resurfaced the flywheel already, it should be ok...although if its been done once already i might buy a new one...
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
