Cloyes timing sets and crank sensor chopper wheel?
Old Sep 9, 2004 | 12:30 PM
  #16
duckhead4life's Avatar
Re: Cloyes timing sets and crank sensor chopper wheel?
so where can i go about buying one of these crank hubs at for a 95. and how much do they normally run.
Old Sep 9, 2004 | 02:06 PM
  #17
Originally Posted by simple
if you look thru shoebox's cam install page, you can see what you're getting into but it doesnt show much about the CPS reluctor in any of the pictures
http://shbox.com/ci/cam_install.html
something to look at and reference tho
other then his site, i dont have any pictures. try searching on here for something
Maybe this will help, but you are right-no reluctor pics in my cam page because mine is a 1995.
Old Sep 10, 2004 | 02:32 AM
  #18
thanks shoebox. and i was looking at the exploded diagram but i didnt see anything called a crak hub. which piece is that
Old Sep 10, 2004 | 10:04 AM
  #19
LT4orbust's Avatar
it only says "hub". from the far left it's the 3rd or 4 th item with the 3 ears on it
Old Sep 10, 2004 | 12:07 PM
  #20
blown383's Avatar
I just went with a 95 style hub and a OBD I conversion...however the cheap way to do it is measure the thickness of the CPS wheel, depth of the HUB, length of the crank snout, and mark the hub on the outside so you know where to stop pressing the hub on.
-B
Old Sep 11, 2004 | 05:54 AM
  #21
damn there it was clear as day. i now feel like an ***. does anyone know where to buy this crank hub at. is this something i can just get on-line. or is it something that i will have to find in the junkyard
Old Sep 11, 2004 | 08:49 AM
  #22
-B
...but if you stop short of putting the hub all the way on, your pulley will be out of alignment and the hub may end up spinning on the crank, because it is not clamped to the front of the crank snout.
There are some makers of aftermarket hubs (I saw one somewhere...), but they are probably more expensive than wholesale at the dealer. A salvage yard is obviously an option.
A's 91 Z28
Jan 11, 2015 10:58 AM
TitoPR221
Jan 2, 2015 03:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
