Cloyes Double roller users inside
Old Jun 15, 2005 | 09:50 PM
blackztpi's Avatar
my cloyes double roller seems kind of loose when it's all setup. it has a noticeable amount of slack. anybody else notice this on their cloyed dr's?
Old Jun 15, 2005 | 10:08 PM
turbo_Z's Avatar
Re: Cloyes Double roller users inside
Mine was pretty tight. Whats the part number on the box?
Old Jun 15, 2005 | 10:10 PM
blackztpi's Avatar
i don't have the box. i bought the whole motor used, and it ran great. i was surprised to see the slack when i removed the cover
Old Jun 15, 2005 | 10:24 PM
ibanez6rg's Avatar
Mine was tight.
Old Jun 15, 2005 | 10:25 PM
Silvershark's Avatar
Mine was tight.
Here is a picture of mine installed.
http://www.akgaming.com/~kendall/images/100_0019.jpg
Old Jun 16, 2005 | 12:49 PM
blackztpi's Avatar
ttt
Old Jun 16, 2005 | 01:43 PM
QUASARBLUEZ28's Avatar
Mine was tight on the install. I imagine some stretching will occur but I'd replace it if in doubt.
Old Jun 16, 2005 | 02:08 PM
ayalam's Avatar
mine was tight too. Hey turbo z did you ever put the crank shaft position sensor wheel back in after the double roller or did you just delete the codes.
Old Jun 16, 2005 | 02:28 PM
If it is used, then maybe it is just worn.
Old Jun 16, 2005 | 02:50 PM
disco192's Avatar
if in doubt, just replace it. They arent expensive.
HarleyZ28
Oct 5, 2015 06:23 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
IDOXLR8
Aug 6, 2002 12:30 PM
