DataMaster
Old Jun 15, 2005 | 01:10 AM
'94 Red Dragon's Avatar
DataMaster
Is there a way that you can run DataMaster all the time instead of saving runs and playing them back. I want to monitor the engine at all time instead of replaying a saved run.
Please Help!
Old Jun 15, 2005 | 02:58 AM
MaxLean's Avatar
Re: DataMaster
There is the monitor function in the record window.
Old Jun 15, 2005 | 08:04 AM
Re: DataMaster
...or obviously, you can watch or monitor as you are recording.
Old Jun 15, 2005 | 01:35 PM
Re: DataMaster
Does the monitor function run the program constantly or does it record for a certain amount.
Old Jun 15, 2005 | 01:36 PM
Re: DataMaster
I dont see no monitor function
Old Jun 15, 2005 | 04:49 PM
MaxLean's Avatar
Re: DataMaster
In the record window, where you start and stop recording, there is a third button: monitor. When using this function, it buffers only 60 or so frames, but the data is coming in real time and not being recorded to a file. And as mentioned previously, you can watch the data in real time when recording a file, of course.
Old Jun 16, 2005 | 03:51 AM
Re: DataMaster
is there a program that tells you your air/fuel ratio or can datamaster do this.
Old Jun 16, 2005 | 08:31 AM
ejfagala's Avatar
Re: DataMaster
Your LTerm Counts and STerm counts are your indications for A/F ratio. The O2s are providing the feed back of what your air fuel is. If you are looking for actual A/F readings such as 13:1 then you need a wide band O2 and a meter, they are around 300-400 bucks and require and another O2 bung wleded in.
Old Jun 16, 2005 | 02:59 PM
Re: DataMaster
How do you read the sterm and lterm and convert it to make sure its running a/f like it should
Old Jun 16, 2005 | 03:05 PM
Re: DataMaster
As far as the ratio the computer is trying to maintain, 128 is perfect. You can judge rich or lean from the deviation above or below that number. There is some good information on Injuneer's page on what all the numbers mean.
Old Jun 16, 2005 | 03:46 PM
Re: DataMaster
Read this, particularly the air/fuel management section.....
http://members.aol.com/InjuneerZZ/ScanMast.htm
There will be a "true - false" test in the morning.....
Bails098
Aug 17, 2015 05:15 PM
jdelaprida
Jul 4, 2015 03:02 AM
jdelaprida
Jun 27, 2015 08:30 PM
Dave69Z
Apr 23, 2003 12:07 AM
JeffK95Z
Nov 13, 2002 12:50 AM
