cloyes double roller???
Old Jul 13, 2004 | 01:39 AM
BadAssed93Z's Avatar
i know its late but maybe someone can answer this.
do i need to upgrade to the vented optispark if i go with the cloyes double roller timing chain?
i know i need to go to an elec. wp but i wasnt sure about the opti.
thanks
Old Jul 13, 2004 | 01:54 AM
Alex94TAGT's Avatar
Someone's always awake.
Yes, you need a vented optispark. The Cloyes does not have the splined shaft in the center of the cam gear, which drives the unvented optispark in the 1992-1994 LT1 . There have been a lot of recent posts regarding this.
However, to upgrade optisparks, you're going to need a 1995+ camshaft (due to variances in the cam snout and dowel pin). Nonetheless the timing cover, electrical harness, vacuum lines, electric waterpump, etc...
I had to grind the timing cover a good deal to make clearance for the double-roller as well. Be prepared...
Old Jul 13, 2004 | 02:09 AM
thanks alex,
i was aware of the the new cam for the new opti and all of that.
i just wasnt sure of the opti.
i have a new came with the longer dowel pin, but i think im gonna swap it for a bigger cam.
Old Jul 13, 2004 | 02:37 AM
Alex94TAGT's Avatar
Cool deal. ~All you need is the 1995+ vented opti and its corresponding components, and you'll be set to go (-well, in addition to the electric wp if you dont have one yet).
I ordered the Cloyes thru Summit for about $80 + shipping.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Bxlt1
Sep 10, 2015 08:16 AM
