Clearence question
Old Feb 9, 2007 | 02:23 PM
JohnnyPappis's Avatar
Clearence question
Ok are there any clearence issues using a stock pan on a LT1 with a 3.875 stroke or would it be better to go with a canton pan? I cant use a winged pan due to clearence issues with my turbo setup? any suggestions?
Old Feb 9, 2007 | 05:15 PM
Chris 96 WS6's Avatar
Yeah, there's going to be clearance issues. Stock pan has to be clearanced for a 3.75" crank so I know a 3.875 is going to need it.
Old Feb 9, 2007 | 05:35 PM
OBE1 95Z28's Avatar
I agree with the answer about; my friend used a stock pan on his 383 and the stock pan had to be massaged.
Old Feb 10, 2007 | 10:07 AM
so what should i do? a non winged canton pan? and with the canton pan would i need the canton pickup because if a 383 needs to be clrenced on a stock pan i dont see how a 396 will cut it but i might be wrong
Old Feb 10, 2007 | 04:26 PM
anyone?
Old Feb 10, 2007 | 05:22 PM
94/96ZsM6s's Avatar
don't know about the stock pan since i did not use it. but i used the canton pan on my 396, and the pan rails and scraper needs to be clearenced. use the canton pan and their pickup especially since your going to install a turbo. also get the high volume pick up if your using a stock LT1 oil pump because of the larger opening where the pickup press fits into the pump. i made the mistake of getting the standard volume one and had to send it back. if you go with the canton pan remember to put only 6quarts in!!!! (5qts in pan+1qt oil filter) and it will register on the ery end of the dipstick.
i've seen TTsetups up front use the canton pan....
Old Feb 10, 2007 | 05:57 PM
Which pan will fit the best for the turbo setup wings are out ofcourse any links?
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
