Clearance on passenger side with jet-hot long tubes??
Old Feb 20, 2004 | 01:48 AM
jeremyferguson's Avatar
Install is almost complete. Take a look at the pic about half way down the page.....does everyone with the jet-hot long tubes have that little clearence? I put in Energy suspension poly motor mounts...could that have done it??
www.cardomain.com/memberpage/528388/2
Old Feb 20, 2004 | 03:32 AM
QCKZ28's Avatar
from what i can tell about that pic, it looks like my jet hots. how is the clearance with the a/c lines and the heater box?
the closest clearance on my jet hots was the driver's side flange. about a 1/4" clearance between the flange and the floorboard.
i also have poly motor mounts and tranny mount.
ps: i pm back about the duals
jesse
QCKZ28's Avatar
jesse
Old Feb 20, 2004 | 03:59 AM
The ac line is real close under the #2 primary. I also have about 1/4" on the driver side floorboard. When the motor torques, does it hit the floorboard?? I might have to take the ole' sludge to it(floorboard).
Pm'ed back about the duals.
Old Feb 20, 2004 | 04:10 AM
QCKZ28's Avatar
after i installed my poly mounts the motor doesnt "torque" anymore. i havent had any problems with the jet hots....
you have mail too
jesse
Old Feb 20, 2004 | 05:53 AM
Amped96's Avatar
There is no clearance between my jethots and the passenger side of the k-member and no clearance with the A/C line either. Maybe I should get me some poly mounts? I still have the stock mounts which have about 115k miles on 'em.
Old Feb 20, 2004 | 04:08 PM
QCKZ28's Avatar
yes sir
Old Feb 20, 2004 | 09:45 PM
Amped96's Avatar
How bad are the vibrations from the poly mounts. I don't even know why I'm asking, cause I'm sure it isn't as bad as the vibration I get now from the header hitting the K-member.
Old Feb 21, 2004 | 12:07 AM
QCKZ28's Avatar
noticeable but not that bad, well for me anyway.
its what you get used
ModdedNerd
Jan 1, 2015 10:56 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
