1994 TA airpump is it that inportant?
Old Feb 20, 2004 | 08:03 PM
Reptile5.7L's Avatar
what its its job ,can i take it out ?
Old Feb 20, 2004 | 11:58 PM
The AIR pump puts air into the exhaust manifolds for about the first 3 minutes after startup, to help the catalytic converter heat up faster. If you have removed the cat, you don't need the AIR. Some people claim that the absence of AIR will cause the cat to fail sooner, but I have not seen any hard evidence of this.
There is absolutely no performance gain related to removing AIR, since it doesn't operate at WOT. You will save about 7# of excess weight.
In the 0BD-I 93-95 models, you can simply disconnect the harness from the pump, and as long as there is a good fuse in the circuit, it will not set a code/SES light.
Old Feb 21, 2004 | 12:12 AM
1msfyter's Avatar
darn...Mne fell off last year while I was driving
PopoFormula
Oct 12, 2015 04:19 PM
greenzee28
Sep 25, 2015 04:29 PM
Formula Steve
Sep 19, 2015 08:48 PM
scottcba1
Sep 8, 2015 09:52 AM
WPHIG2
Aug 27, 2015 06:37 AM
