Clearance from oil pan to pick up...Using Melling HV??
Old Jul 27, 2004 | 10:14 PM
5.7LT1Formula's Avatar
i am going to be using the melling HV oil pump with their shaft that has a metal collar along with a stock pan. Some people have problems with the Melling HV pumps and some do not... is it because of a clearance issue between the pick up and the stock oil pan?? Any mods need to be done for the pan to fit a 383? What clearance should i look for when putting everything back together? The guys at the performance shop suggested i braze the pickup to the pump.
Thanks!!
Old Jul 27, 2004 | 11:07 PM
1racerdude's Avatar
Re: Clearance from oil pan to pick up...Using Melling HV??
No more than 1/2" clearance checked with clay.
A lot of people have the oil climbing the back of the stock oil pan,But that has nothing to do with the HV pump.
If the pickup is not bent in it's housing fit (trying to put it in crooked)and put it in up to its ridge, it won't come out.I have never had one come out,since the '60's and never welded any.DO NOT braze it,you will distort the pump end cap and mess up the oil pressure.If you do weld it with a MIG welder,cool it with air so as not to warp it.
You can buy pumps with the pickup installed.
Why do you think the factory doesn't weld the pickup????
Old Jul 27, 2004 | 11:09 PM
944v8inDFW's Avatar
Two things you can buy a bolt on pickup tube holder from summit or jegs for around $10 wraps around the tube and goes under one bolt. Or you can buy a melling pump with a bolt on pickup. Welding on pump = BAD IMO
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
