Cleaning Lt1 Intake
Old Feb 6, 2009 | 09:06 PM
Connexion2005's Avatar
Cleaning Lt1 Intake
I'm planning on running an intake off a blown motor. The piston let go and sent metal all through the intake. I took it to the local car wash and sprayed it down very well. I can not see any metal remaining and it looks clean inside. I also removed the panel on the bottom for oil drain back and cleaned. Are there any other hidden passages that can still contain metal that need to be cleaned?
Old Feb 6, 2009 | 10:22 PM
sn8ke eatr's Avatar
sounds good..
when i ported my intake i then dunked it in gasoline, washed it out with the hose, let it dry, and shoot some compressed air down into the cervices. beyond that not sure what else u can do..
Old Feb 6, 2009 | 10:28 PM
JP95ZM6's Avatar
I remember how soaked I got washing my intake out at the carwash
Make sure the IAC passages are blown out real well and not plugged, too, if you haven't already.
Old Feb 7, 2009 | 06:44 AM
white97T/A's Avatar
A couple cans or brake cleaner would probably be real effective.
Old Feb 7, 2009 | 03:52 PM
I also realized that their was still oil in the passage for the pcv line that runs into the intake. I'm glad I caught that...
ModdedNerd
Dec 14, 2014 10:28 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
CPFarhood
Jul 25, 2002 02:17 PM
