Cleaning Lt1 Intake
Cleaning Lt1 Intake
I'm planning on running an intake off a blown motor. The piston let go and sent metal all through the intake. I took it to the local car wash and sprayed it down very well. I can not see any metal remaining and it looks clean inside. I also removed the panel on the bottom for oil drain back and cleaned. Are there any other hidden passages that can still contain metal that need to be cleaned?
sounds good..
when i ported my intake i then dunked it in gasoline, washed it out with the hose, let it dry, and shoot some compressed air down into the cervices. beyond that not sure what else u can do..
ModdedNerd
Dec 14, 2014 10:28 AM
