Cleaning Heads & Intake while off
Old Mar 10, 2005 | 01:43 PM
Bawls's Avatar
What would you guys recommend to clean up the inside of the intake, and the heads?
Intake 1
Intake 2
Intake 3
Intake 4
Intake 5
Old Mar 10, 2005 | 01:48 PM
1-bad-z28's Avatar
Re: Cleaning Heads & Intake while off
looks like you had an intake leak. You could bring them to a machine shop and have them hot tanked. Or you could use some degreaser and a brush. Quick question for ya, why didn't you leave the fuel rail on the intake when you took it off? Seems like a lot of extra work you did.
Old Mar 10, 2005 | 01:50 PM
Bawls's Avatar
Didn't have a ride to get the fuel line disconnects.
Old Mar 10, 2005 | 01:52 PM
Bawls's Avatar
Originally Posted by robvas
Eww. Thats how mine looked. I think the previous owner forgot to change the oil.
http://robvas.dyndns.org/rob/cars/97z28/openlt1.jpg
Looked? What'd you do to clean it up?
Old Mar 10, 2005 | 01:54 PM
Bawls's Avatar
How much would a shop charge to hot tank? I need to take the heads in anyway to have the header bolts that snapped off drilled/tapped.
Old Mar 10, 2005 | 02:11 PM
1-bad-z28's Avatar
you could get those bolts out yourself with a drill and a screw extractor. You would have to call a local machine shop to find out how much it costs. Things like that vary a lot from place to place. To give you an idea, it cost $125 to hot tank my block, magnaflux, install new freeze plugs, bore the cylinders, and hone them and deck the block. So just hot tanking your heads and intake shouldn't be much. They would look brand new when done though.
Old Mar 10, 2005 | 02:13 PM
Bawls's Avatar
Yeah i had a local machine shop quote me $550 for heads/intake and thats with new valve seals, and the heads resurfaced. Really not looking to do all that.
mikey4play
Mar 15, 2015 11:45 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
