Cleaned my maf
Old Mar 9, 2004 | 07:37 AM
btchincamaro's Avatar
Cleaned my maf
My car had been running like crap for a while so I finally had a friend to log some data on it. Found out the maf was reading real low, like 178 g/s at 5200rpm and the O2's were real lean. Cleaned the maf last night at his suggestion and OMFG. Feels like a new car again. Hasn't run that good since I bought it. Wish I'd thought of this a year ago. Thats all. Just thought I'd share.
Old Mar 9, 2004 | 07:51 AM
350 HRSS's Avatar
I done that about a year ago w/ some alcohol. WOW.
The dirt on the electrodes can really cause some false readings.
Feels like a brand new car
Old Mar 9, 2004 | 07:55 AM
cndctrdj's Avatar
how do you clean it out. just poor some alcohol on it. i know the sensors are really sensitive. so i figure you can't actually touch it with anything
Old Mar 9, 2004 | 08:21 AM
ppmz28's Avatar
I want to know this to, how do you clean it, I know my car could use it.
Old Mar 9, 2004 | 08:35 AM
I popped the screen out by removing the big ring clip with a screwdriver. Then I hosed the whole thing down the brake parts cleaner. After I knocked the loose stuff off with the brake cleaner I took a q-tip and soaked it with the cleaner and gently rubbed on the sensors. They came clean pretty quick. Then I hosed it off again with the brake cleaner. Let it dry, cleaned the screen off real good, put it back together and voila.
Old Mar 9, 2004 | 08:39 AM
ppmz28's Avatar
do you seperate the housing and take out the sensor or leave it in while cleaning, i know your not suppose to touch it. I don't have that screen I took it out and it isn't going back in.
Old Mar 9, 2004 | 10:02 AM
Dont take apart the housing. If you have no screen just spray some brake cleaner or contact cleaner in there and spray some on a q-tip and carefully wipe the 3 resistor looking things clean. They wont break if you're gentle. They're stronger than they look.
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
