Clean your MAF regularly!
Old May 22, 2007 | 09:58 PM
  #31
DZNUTTS's Avatar
who woulda thought.
Old May 22, 2007 | 10:07 PM
  #32
Voridaeus's Avatar
Originally Posted by DZNUTTS
who woulda thought.
I know it's not rocket science, but fwiw I think a lot of people over look this item. While it may not cure the whole problem, it just might be part of it.
Old May 23, 2007 | 02:40 PM
  #33
gas huffer's Avatar
since this post i even cleaned mine and it needed it. napa has maf cleaner for 5 bucks. works good
Old May 23, 2007 | 05:15 PM
  #34
SkiBumDreams's Avatar
Help!
So i over oiled my k&n, yea i know i am a dumb***. so did it permanently screw up my maf or will a good cleaning (which i am in th eprocess of) fix it up and make it ok?
Old May 23, 2007 | 10:26 PM
  #35
Geezer powered's Avatar
Just for the hell of it I know what I'm doing tomorrow. I to have over oiled my filter's. Not just once but for 6yrs I've had the car.
Old May 23, 2007 | 10:33 PM
  #36
Z28LT1_Just_Nasty's Avatar
For the hell of it today I cleaned my MAF and my filter while I was at it. The butt-o-meter tells me it helped some. Feels like it cruises better, especially in OD when I'm giving it a little gas. Not sure if its completely from cleaning the filter or the MAF but both were pretty dirty.
Giving the OP credit, the thought never crossed my mind to clean my MAF. Thanks for the tip!
Old May 24, 2007 | 10:34 AM
  #37
micfly83's Avatar
Autozone said they didnt have it.
and I just called NAPA and they didnt have it.
will the "electric parts" cleaner work or should I continue the search...
Old May 24, 2007 | 11:54 AM
  #38
oneclean97z's Avatar
dont use carburator or throttle body cleaner on the maf, it is too sensitive and will damage/ruin the fine electrical wires that hang there, trust me ive done it and either the maf cleaner can or the throttle body cleaner can i have say the same thing. no bueno
Old May 24, 2007 | 12:23 PM
  #39
micfly83's Avatar
Dumb question I know
but what exactly am I spraying down here
Looks like the sensor in the middle is blcoked off on both sides...
unless I have to disassemble it?
Old May 24, 2007 | 02:26 PM
  #40
micfly83's Avatar
Better yet does anyone now the size for those torx bolts
Old May 24, 2007 | 03:18 PM
  #41
Joe B's Avatar
Most of us (permenantly) remove the restrictive screens on both sides , then you will be able to see the resistors much easier, and to clean them......if you remove the screens , just be VERY careful not to bend anything inword that could hit the resistors......
Old May 24, 2007 | 03:19 PM
  #42
Joe B's Avatar
No need to take the torx screws out
Old May 24, 2007 | 03:25 PM
  #43
Joe B's Avatar
You can also use regular rubbing alcohol for the cleaner.....either poured right onto the resistors (from a filled cap).....or dip a Q-tip in the alcohol to where it's "completely" saturated , then VERY lightly dab the resistors.......I've been doing it this way for MANY MANY years on several MAF's , and it works perfect...........Joe
Old May 24, 2007 | 04:12 PM
  #44
Dave1980's Avatar
I use it. Some will not agree, it is safe and I have 0 issues with it. Like stated you can use 90% isopropel alcohol with a q tip, just be carful not to snag the resistors ends as they are hanging there.
Old May 24, 2007 | 04:17 PM
  #45
isnt there a downfall to removing the maf screen?
