Clean your MAF regularly!
Old May 19, 2007 | 01:38 PM
Voridaeus's Avatar
I just solved all of my lack of low RPM torque and hesitation problems! *knock on wood* I actually bought the CRC MAF cleaner like 2 months ago, but waited to do it while I saved up to buy a replacement MAF unit, just in case. I was paranoid my luck was going to kill it, so I waited.
But damn! I had no idea a dirty MAF sensor would be so problematic. I actually first noticed the difference pulling out of my parking spot as it's going up a slight incline. Before, the car would really try to stall out since it's up hill with little room to accelerate. This time, however, it had no problems at all.
Also, I just took it on a 200 mile drive with about as much mix of city/highway as I normally. I drove it how I normally drive, and I noticed my fuel mileage increased from around 13-14 to about 17-18.
Now if I can just save up enough money to fix my exhaust leak, I'll be a happy camper, and I'm sure that will improve my fuel economy even more.
Old May 19, 2007 | 02:33 PM
2000GTP's Avatar
Alot of hard to trace driveability problems have been solved with a can of MAF cleaner and a q-tip.
Old May 19, 2007 | 04:59 PM
stereomandan's Avatar
Yeah, when I cleaned mine(first time in 50k miles after I bought it new), I couldn't believe how much smoother my acceleration was. Now, each cleaning doesn't result in nearly as much benefit, but that's because it stays clean since I do it once a year.
Dan
Old May 19, 2007 | 09:03 PM
windsma's Avatar
i soaked mine in soap and water over night and now it doesnt work.
JK
off subject but,
I washed my engine compartmen on my 3000gt like i always do. but i forgot that my dumbass broinlaw (VWidiot) cracked it when he used a screwdriver to try to adjust my MAF, he is such a dumbass. When i found the problem i opened it back up and water was puddled all over my circuit board. zzzzzzziiiiiiiiittttttttt
Anyway that was a $50 mistake, FYI
Old May 19, 2007 | 09:14 PM
1FASASZ's Avatar
how do you clean your mass air? i always thought that waS A big no no
Old May 19, 2007 | 09:52 PM
wrd1972's Avatar
A lot of people will end up contaminating the MAF elements by over oiling their K&N filters. I have used tuner cleaner in the past with good results and it is certainly worth doing.
Old May 20, 2007 | 04:49 PM
Voridaeus's Avatar
Disassemble ends from the sensor.
Spray down with a can of MAF cleaner. If you have steady precise hands you can use a q-tip, otherwise just spray it and let it drip off the dirt. The cleaner evaporates quickly so it's completely dry in like 5 seconds.
I have large unsteady hands so the q-tip was not an option for me. It still worked fine though.
Old May 20, 2007 | 07:59 PM
Dave1980's Avatar
also people should watch out so the q tip does not snag the elements ends.
Old May 20, 2007 | 08:20 PM
Don 97 SS's Avatar
Unhappy
Interesting thread.
Just today, I scanned my ride (rough idle and hesitation with a DTC light) and got a P0100 ( Sensor Circuit Insuffcient Activity). I cleaned my MAF carefully but it didn't quiet the code. Hmmm, I am not sure what to check next. Any suggestions? I never experienced any problems with a MAF before.
Old May 21, 2007 | 02:54 PM
95 Z/28 LT1's Avatar
Super Moderator
Try checking the ECM ground.
Originally Posted by Don 97 SS
Interesting thread.
Old May 21, 2007 | 03:37 PM
Terran2k's Avatar
cleaned my MAF a few years ago with some electrical contact cleaner, dries with no residue
Old May 21, 2007 | 05:01 PM
micfly83's Avatar
Where do you get MAF cleaner from?
Old May 21, 2007 | 05:23 PM
Voridaeus's Avatar
I got a can of CRC brand MAF cleaner at Autozone.
Old May 21, 2007 | 05:30 PM
ttop1986's Avatar
wtf, I just got back from autozone and they didn't have anything called "MAF Cleaner". I asked the guy, and he gave me STP throttle body and air intake cleaner. Will this work? I don't want to mess up my MAF sensor. It says nothing on it about cleaning MAF sensors.
Old May 21, 2007 | 06:21 PM
bombebomb's Avatar
I don't know, but if I were to guess, id say no.
