Clack Clack Clack sound
Old Apr 2, 2004 | 08:43 AM
  #31
OffspringZ28's Avatar
JJ im thinking its a really loose rocker arm. with the engine off pull the valve cover and see if you can wiggle em side to side more than normal with just your fingers. mine was making this horrendous sound you speak of and one rocker had almost completely come off. i got lucky it didnt come off or do any valve damage.
Old Apr 2, 2004 | 12:14 PM
  #32
JJ's95B4C's Avatar
Chris... was it a clanking sound, or a ticking? I was able to wiggle some of the rockers side to side...
Old May 11, 2004 | 08:49 PM
  #33
"White Knight"'s Avatar
Rockers
Old May 11, 2004 | 09:32 PM
  #34
Vomit God's Avatar
Originally posted by Dave88LX
Yeah...my videos are called clack1.mpg and clack2.mpg....I hope you have a click or a tap and not a clack.
http://paradox.shacknet.nu/dave88lx/formula/clack1.mpg
http://paradox.shacknet.nu/dave88lx/formula/clack2.mpg
OMFG!!!!!!!!!!! I can't believe that I'd ever hear a sound like that coming from an LT1!!!
I thought my "ticking" was bad, but it turned out to be 2 hand loose, yes.. "2 hand loose" spark plugs!! It was both an exhaust leak and a spark jump "snaping" freaking me out.. Spark was jumping cause the platinum on the ground prong was burnt off, leaving the 2 plugs gapped at .060" : /
Old May 20, 2004 | 03:38 PM
  #35
TenaciousZ's Avatar
after my head swap and adjusting the rockers I heard a random clacking, it would get louder with throttle input. took the valve covers off and found one rocker arm real loose.. almost to the point of the pushrod stepping out We thought we adjusted them perfectly but since the car sat for a month the lifters must've bled. I readjusted them and that clacking went away.
Old May 20, 2004 | 03:46 PM
  #36
rob97ss's Avatar
That sucks the same thing happen to me after cam install,i hoped for the best but it was a spun bearing,I dont care what anyone says the chances of spinning a bearing after a cam install are against you,there are more people that spin bearings after a cam install,than do not in an LT1 motor!!!!
Old May 26, 2004 | 11:07 PM
  #37
JJ's95B4C's Avatar
I found the problem. It IS a bad bearing. Its at the shop now getting rebuilt. I'm just going to rebuild it back to stock, drive it for a while. Thanks for all the help guys. Add me to the list of people who spun a bearing after a cam install in a LT1. I guess the mix of bearings splashed with coolant and revving the engine higher was not a good combination.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
