Chugging at steady speed
Old Aug 13, 2007 | 07:33 PM
96SilverZ's Avatar
My 96Z has developed a slight chugging problem at steady speed. I have found a crack at the end of the black rubber tube that runs from the TB to the passenger side valve cover(fresh air tube?). Would this crack cause the problem?
Old Aug 13, 2007 | 07:40 PM
MeanGreen97Z's Avatar
That wouldn't cause a chug directly. It could however cause you to be sucking in dirty air and cruding up the oil. When was your last plug change and how old are your wires? Start looking for a miss. Sounds more like that or a bad fuel filter. Always start with the little things.
Old Aug 13, 2007 | 08:12 PM
96SilverZ's Avatar
Both are fresh.
Also, the car runs strong under acceleration...
Old Aug 13, 2007 | 08:21 PM
Dave89IROC's Avatar
well, it would skew the MAF readings, so, anything is possible
Old Aug 13, 2007 | 08:24 PM
96SilverZ's Avatar
that was kinda my thought...
CaptainObviousI
29
Apr 29, 2021 10:35 PM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
Jessie4tin
Jan 7, 2015 08:53 AM
