Roller tip question
Well i have already have the rollertip rockers, springs, guidplates, pushrods, and new studs. I got a good deal on all of them but i was considering selling the roller tip rockers. But how much hp/tq you think it will gain?
Work is force times distance. There isn't much distance of motion at the rocker tip, as compared to the fulcrum. Nearly zero, in fact. And, the force is higher at the fulcrum than the tip. So, at the fulcrum, more force x more distance = more work done to overcome friction. So, more power can be saved ('made') by reducing friction at the fulcrum.
I agree. Here's how I look at it:
Distance in terms of metal-to-metal sliding, not up/down travel. The sliding distance (friction causing element of motion) is only as long as the contact pattern on the valve tip, or maybe 1/16 inch. Whereas the friction distance at the fulcrum is the radius of the fulcrum bearing surface x the angle of rotation of the rocker.
Hurin
Dec 13, 2014 07:38 PM
