Chip for an LT1
www.fastchip.com
Ed programmed my stroker application.
BTW you'll have to send him your PCM because there are no chips for 94+. He has to reprogram the PCM itself.
Just an FYI, your car doesn't use a "chip" like 93's and older Camaro's, 94 and up have a PCM that you can have reprogrammed. Unless you are looking to have some things corrected like the speedometer for the gear change or something like that I'm not sure why you would want to have any programming done for the mods you have listed so far. If you do need programming I would suggest www.pcmforless.com he can do anything you would need and is only $99 for your model year.
Jul 4, 2005 05:00 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
