checking bad fuel press. regulator-which vac hose?
OK, did search. If I want to find out if my FPR is bad, which vac hose do I pull to see if there is fuel in it? Where is it at and what does it look like? Changed oil and it smelled like it should have been about 3/4 oil and 1/4 fuel! At least my fuel gage still said I had a full tank!
Short line, less than 12" that runs from the passenger side/rear of the intake manifold to the FPR. You can see it in this picture. It has fallen off the FPR and is laying against the EGR valve, but you can see where it should connect on the FPR (the FPR in the picutre is not stock, but the vacuum connection is in the same location).
Alex Barnes
Jan 24, 2015 10:21 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
