checked fuel pressure, this sound ok
Old Apr 4, 2005 | 08:57 PM
bowtiethunder's Avatar
with key on engine off- 42psi
with engine running at idle- 36 psi
simulated wot- 46 psi
Is this ok?
Old Apr 4, 2005 | 09:26 PM
Kataklysm's Avatar
Re: checked fuel pressure, this sound ok
Ya thats fine. Mines about 40 at idle.
Old Apr 4, 2005 | 10:50 PM
What is "simulated WOT"? You can only measure the effectiveness of the fuel pump/pressure by having the engine under max load near peak RPM.
Let it idle. Pull the vacuum compensation line off the FPR (hold your finger over the hose, so it doesn't mess up the idle). Pressure spec is 41-47psi. Reconnect the vacuum compensation line.... pressure should drop proportional to engine vacuum. 8-10psi below the "no vacuum" level would be normal with a stock cam.
Then tape the gauge to the outside of the windshield, and take it up to peak HP and the pressure should not be more than 1 or 2psi below the "no vacuum" reading.
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
