Check Light on after Cat Gutout!
Old Feb 6, 2009 | 01:19 PM
joeytweaks's Avatar
My Car runs so much better now that i cleard the cat today!!! Only prob is that the check engine light still comes on after while...maybe o2's? but they are before the cat on my car so i doubt that is it, any idea's?
95 LT1 obd1 but with a 16pin connector..
and i know obd1 isnt that smart so what the hell could it be looking at????
please help
Old Feb 6, 2009 | 01:29 PM
Air-Adam's Avatar
The OBD2 cars will have an O2 sensor behind each cat just to see that the cat is working. If the cat is gutted or removed, that O2 sensor will not read within the right range and a red flag goes up. That will make the SES light come on.
I didn't think the OBD1 cars had the downstream O2 sensor(s) though?
What code are you getting? Its very possible its just coincidental timing...
Old Feb 6, 2009 | 01:34 PM
Stl94LT1's Avatar
With the reduced backpressure, it's probably an "EGR" code.
Old Feb 6, 2009 | 01:39 PM
joeytweaks's Avatar
nah it happend after my cat cloged solid while driving to hooters and it burned the elbow off the air smog pump bullsht setup on this Lt1 and almost burned my lt1 to the ground because as you all know the fuel lines are right near the maf then run to the back/ And it was cloged so bad that the check valves on the manifold that go to the air pump were blowing flames out as i drove her cause it burned off the elbow....thats when all this crap started,anyways that all fixed with drain plugs and a gut'd cat i just need to know how to check the code im getting?
Old Feb 6, 2009 | 01:41 PM
joeytweaks's Avatar
maybe an egr? can i cycle the key to get codes?
Old Feb 6, 2009 | 03:17 PM
Dave1980's Avatar
I think that only applies to 93 model. Go to autozone and see what code it is.
Old Feb 6, 2009 | 03:46 PM
joeytweaks's Avatar
tks.... i will
Old Feb 6, 2009 | 03:54 PM
moparman's Avatar
Don't bother going to Autozone. They won't be able to read the code. You'll need an OBDI scanner with the correct connector for the '95, or use jumpers on the OBDI scanner, per instructions on Shoebox's site.
Old Feb 6, 2009 | 10:49 PM
OneShoe50's Avatar
Mmmmm Hooters........
Old Feb 7, 2009 | 03:56 AM
Air-Adam's Avatar
Can't the OBD1 LT1 cars have the pins 'jumped' with a paperclip to flash the codes, like the TPI cars could?
Old Feb 7, 2009 | 09:06 AM
moparman's Avatar
No, '93 was the last year you could do that.
Old Feb 7, 2009 | 12:07 PM
You need an OBD-I scanner, like the Auto X-Ray, or software like FreeScan or TTS DataMaster. And you need an adapter for the 12-pin to 16-pin connection. Or you need to use jumper wires as shown on Shoebox's site:
http://shbox.com/1/xraycable.jpg
As noted above, 93 was the last year you could short the pins.
Old Feb 7, 2009 | 03:49 PM
Air-Adam's Avatar
Ok, gotcha... my 3rdgen could have the codes read like that, but my LT1 is an OBD2 car, so thats not an option for that car anyway lol. Now I know.
Old Feb 7, 2009 | 09:56 PM
Actually there's no way to know anything at all about your car, since you haven't taken the time to set up a "signature" with basic info about it.
squarehead
Jan 15, 2015 07:02 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
Dec 1, 2014 08:08 AM
danielbmx
Aug 27, 2002 11:11 PM
