check gauges light flickers on and off...
Old Jul 30, 2007 | 03:34 AM
ZX636RIDER03's Avatar
Question check gauges light flickers on and off...
recently i opened up the throttle getting onto the freeway and then all of a sudden my check gauges light comes on and stays on and then flickers on and off when i rev the engine. theres probably endless things that could make this happen but does anyone know where to start? thanks...
Old Jul 30, 2007 | 06:56 AM
Did you look at your gauges at that time? That's what it is telling you to do.
Old Jul 30, 2007 | 08:43 AM
JohnD's Avatar
Was it raining at the time? I was in a very heavy rainstorm and had the car do that to me once. Something in the ign. system got intermittently wet enough to cause a misfire.
Old Jul 30, 2007 | 10:06 AM
96LT1TX's Avatar
I have always gotten these with an "intermittent missfire" and that is the code that SHOULD come up if you go get it scanned. I have had it happen because of burnt plug wires or the wet opti as well. HTH
Old Jul 30, 2007 | 01:33 PM
96LT1TX's Avatar
Ok, sorry for the double post, was it a Check Guages light or the Service Engine Soon light? On my car, I have the 2 lights. For Check Guages light I would say if it is blinking it is probably either: low oil pressure, rear hatch not closed all the way, or coolant way hot.
For service engine soon, see my previous post.
I think the Check Guages light comes on when the SES light blinks, but I am not positive on that one.
Old Jul 30, 2007 | 03:26 PM
Check gauges comes on when one of the gauge readings is out of normal range (low oil pressure, low voltage, etc.). It means: "Check (look at) the gauges!".
Old Jul 30, 2007 | 03:43 PM
voltage/engine temp/oil pressure all seem to work fine, i did change my oil out to fully synthetic mobile 1 at 10w30 instead of 5w30, and its the little light in the left hand corner not the ses light i have a scan tool for that and it reads that all codes are clear. how about the altenator would that do it the voltage fluctuates sometimes up and down when i rev the engine but it did that way before i was having this problem.
Old Jul 30, 2007 | 03:44 PM
96LT1TX's Avatar
Thanks for the clarification, so if it is a blinking SES light this would not be included in the "blinking check guages". sorry for the first post, doesnt apply.
Old May 4, 2009 | 11:50 PM
Domn8er's Avatar
Did you ever figure out what it was?? My car just started doing this a few days ago and yes all of the gauges are fine.. no of them are reading in the low range??
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
