check gauges light flickers on and off...
recently i opened up the throttle getting onto the freeway and then all of a sudden my check gauges light comes on and stays on and then flickers on and off when i rev the engine. theres probably endless things that could make this happen but does anyone know where to start? thanks...
I have always gotten these with an "intermittent missfire" and that is the code that SHOULD come up if you go get it scanned. I have had it happen because of burnt plug wires or the wet opti as well. HTH
Ok, sorry for the double post, was it a Check Guages light or the Service Engine Soon light? On my car, I have the 2 lights. For Check Guages light I would say if it is blinking it is probably either: low oil pressure, rear hatch not closed all the way, or coolant way hot.
For service engine soon, see my previous post.
I think the Check Guages light comes on when the SES light blinks, but I am not positive on that one.
voltage/engine temp/oil pressure all seem to work fine, i did change my oil out to fully synthetic mobile 1 at 10w30 instead of 5w30, and its the little light in the left hand corner not the ses light i have a scan tool for that and it reads that all codes are clear. how about the altenator would that do it the voltage fluctuates sometimes up and down when i rev the engine but it did that way before i was having this problem.
Jan 5, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
