Check engine light after longtube install
Old Apr 12, 2010 | 09:51 PM
94z28_08's Avatar
I just got done with a pretty big project including longtubes. The car runs fine and everything. But the check engine light stays on and makes it go into limp mode. They are non emissions headers. I was assuming it was the egr being gone and the computer relearning it. I had the egr blocked off previously and it would randomly come on and throw an egr code. Will I have to get it tuned out or will it possibly relearn. This is a 94 z28 m6. Any advice would be greatly appreciated.
Old Apr 12, 2010 | 09:56 PM
The computer can't relearn that the EGR is gone. If you don't want it to be a problem, it needs to be tuned out. Until you have it scanned, you really don't know if the EGR is the issue (or the only issue). When the check engine light comes on, you scan it to see why.
Old Apr 12, 2010 | 10:09 PM
Why assume its the EGR being gone. Scan it and find out why its on.
Old Apr 12, 2010 | 10:10 PM
87bandit's Avatar
do you have a y-pipe, x-pipe, or some kind of header extensions on there?
if not your car is gonna be reading alot of clean air from outside and throw a code
did you make your own o2 extensions?
Old Apr 12, 2010 | 10:18 PM
94z28_08's Avatar
alright I just finished it so I haven't scanned it yet I'll scan it at work tomorrow and go from there. thanks for the help.
Old Apr 12, 2010 | 10:20 PM
94z28_08's Avatar
it has a off road y pipe and i bought the casper extensions
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
