Check Engine Light
Old May 19, 2007 | 04:15 PM
  #16
ricehammer's Avatar
I had Advance scan a car here in Roanoke a few years back. Give them a call and find out.
Old May 20, 2007 | 10:17 PM
  #17
gunz41's Avatar
Ok I got it checked guys and it was O2 sensor(left one) and was running lean. it was also EAS thing. I was reading online to find a cheap one and on auto zone and advanced websites it says u need 2, but I just need one right? How long will it take me to fix?
Old May 20, 2007 | 11:11 PM
  #18
jwbeaumont's Avatar
Trouble code and fan
Originally Posted by shoebox
You are not having a problem with the check engine light, but a trouble code that it is trying to tell you about. You must use a scanner to retrieve the code. A paper clip will not work on 1994 and later.
BTW, the fans come on with most trouble codes, so that is why you hear it. Get it scanned and find out what the issue is.
The fans come on when the trouble code comes up?
I have been having trouble diagnosing a trouble code on my 93 Z28, and part of the problem is relating it to the fan coming on. Am I to understand that the fan coming on may not be related at all to the trouble code? My trouble code (26) says it is the EVAP purge solenoid. Is there a reason the fan would come on, but perhaps not be related to the actual problem?
Old May 21, 2007 | 07:02 AM
  #19
moparman's Avatar
The fans are programmed to come on when the SES comes on.
Old May 21, 2007 | 12:20 PM
  #20
If that's the description of DTC 26 you found, you're using the wrong code list. That's only for 94-95 models. The 93's have their own codes lists, reflecting some of the differences in the 93 ECM. DTC 26 is for (from Shoebox's LT1 code list):
Quad-Driver Module (QDM) #1 circuit applies to:
- AIR pump relay circuit
- EGR solenoid
- EVAP solenoid
I'm really not sure that all SES/codes lights turn on the fans. But a blown fuse for the AIR pump relay circuit is the most common problem that does turn the fans on.
Link to Shoebox's list (93 codes are in the right-hand column on the OBD-I page):
http://shbox.com/1/Dtcs.htm
Old May 22, 2007 | 07:05 PM
  #21
gunz41's Avatar
Hey guys I had a blown fuse for the air pump and I changed it and the light is off. The trouble codes for the car were 13, 29, and 44. But no more light and the guy at advanced said they couldnt test it when light is off. So could it just have been that fuse making the O2 sensor code come up too?
Old May 22, 2007 | 10:16 PM
  #22
jwbeaumont's Avatar
- EGR solenoid
- EVAP solenoid
Dang...I guess I have to look a little harder. I have a code scanner that is supposedly designed for my vehicle and it gives the same thing. I will look at some of the other possibles on your list, though.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
