Cheapest rebuild?
Old Sep 9, 2007 | 08:24 PM
bombebomb's Avatar
Cheapest rebuild?
I spun a rod or main bearing about a month ago, and I need to get this car back on the road for as cheap as possible, I was thinking to do a stock rebuild, my step dad can do the putting back together part. Can I use all my stock parts that are already in and just do the bearings? Or do I need to buy new cam/lifters? Pretty much whats the cheapest (but not a pile of junk) way I can do this. I dont want to go .30 over, and I dont want to buy a new crank because money is tight. and I cant seem to find a lt1 thats already built cheap yet. I found a caprice one, but then it will cost me another $200 to get pcm fixed.
Old Sep 9, 2007 | 08:55 PM
MeanGreen97Z's Avatar
Go to Autozone and get a reman motor! I don't care what anyone says... they get them from a quality shop and you cant beat the price!
Old Sep 9, 2007 | 08:58 PM
dangalla's Avatar
if you spun a rod or main bearing there is a good chance you will atleast need to have the crank refinished
other than that its all up to you, can you re-use everything that was stock, sure, do i recomend it, no
Old Sep 9, 2007 | 09:06 PM
bombebomb's Avatar
So I can reuse all other parts then? I dont need to buy new cam or lifters just basicly a rebuild kit? And have the crank checked.
Old Sep 9, 2007 | 09:08 PM
1997blackz28's Avatar
it really depends on what the parts look like when you pull them. don't use stuff you pull that is questionable, because it may be cheap now but will cost more when you have to do everything all over again not too far down the road. however if the parts look to be in good shape no harm in reusing stuff
Old Sep 9, 2007 | 09:23 PM
bombebomb's Avatar
Ok, i just need to get it back up long enough to do the build that id perfer, so I dont have to drive around some Pos 500 doller car that has little or no power.
Old Sep 9, 2007 | 10:35 PM
reamo04's Avatar
how much/little $$ do u have?
You could get a quality eagle or scat cast crank, and both make a pretty good, yet cheap H-beam rod. I know Javier on here runs SCAT rods with his LE2/LE3 setup
Old Sep 9, 2007 | 11:00 PM
95Blackhawk's Avatar
If you want cheap, just make sure and don't go "while I have it apart, I might as well XXX". That will cost you money.
Old Sep 10, 2007 | 12:54 AM
bombebomb's Avatar
thats 180~ I dont have.
Theres not way I can go "while its apart" its either, this, or a pos. So lol plus I think im having withdraws from sotp feeling.
Old Sep 10, 2007 | 01:04 AM
MachinistOne's Avatar
If you spun a rod bearing, get the crank ground ($100) and the rods resized ($100), new bearings and put it back together. If you spun a main bearing(unlikely) the block may be junk.
You don't need to replace the cam/lifters, this is not a flat tappet motor. A new timing chain would be a very good idea.
Old Sep 10, 2007 | 05:01 AM
rskrause's Avatar
Moderator
You won't know what''s good until you tear it down and inspect it. But as was said, the cam and lifters are in all likelihood good to go. Really, the whole vavetrain is probably fine.
Rich
Old Sep 11, 2007 | 03:47 PM
bombebomb's Avatar
Ok, thats what I wanted to hear, ill be looking into it. Thanks again guys
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
