cheaper to build your own short block, or go and buy one?
Old Nov 20, 2004 | 07:35 AM
acslinger2525's Avatar
just crunching some numbers, and i am wondering if it is cheaper to build your own short block, or is it cheaper to go through an engine builder that has them already built. I am looking at a 355 or 383 to hold 10lbs of boost.
sc smith
Old Nov 20, 2004 | 07:49 AM
jkipp84's Avatar
Re: cheaper to build your own short block, or go and buy one?
From what I found around here, it was cheaper to go with a local shop. What kept from going with any of them was how disgusting they were. Every single one was a total mess. I can't stand that in a machine shop, personally.
Old Nov 20, 2004 | 08:48 AM
rskrause's Avatar
Moderator
It's the machining and the parts that are expensive. Most builders are only charging $3-400 for engine assembly, so that's the max you will save. But if you know how to do it, have the time, tools, and space, why not? But don't try to fake your way through it for a few hundred dollars. Improper assembly can turn thousands of dollars of parts into scrap in no time!
Rich
Old Nov 20, 2004 | 09:02 AM
does anyone know of a company that sells a 383 or a 355 short block already assembled? i have 5 grand to spend, the only thing i need is the short block. if you know a website or company that sells the short blocks, email me at acslinger2525@aol.com
pimpss96
Feb 12, 2015 01:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
sskevinm
Dec 18, 2014 11:16 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
