cheap shaft mount rockers?
Re: cheap shaft mount rockers?
Originally Posted by DiabloGT
so i dont need shaft mounted rockers? so like normal comp cams or w/e will work? i thought ONLY shaft mount work on afr 227's?
so what kind of custom work do you have to do to make the comps work?
Once ya got the plates adjusted mark them and have welded.I used an old head as a jig to hold them while welding,just set them on their marks,tighten studs and weld.Ya might contact AFR to see about their guide plates,They may be a bolt on.
Victor Lamb
Aug 26, 2017 02:52 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
Apr 16, 2015 09:57 AM
