cheap shaft mount rockers?
Old Oct 2, 2005 | 12:56 PM
DiabloGT's Avatar
are there any cheaper rocker arms than the t&d for $1000? that would work on the afr 227 heads?
thanks
Old Oct 2, 2005 | 06:26 PM
1racerdude's Avatar
Re: cheap shaft mount rockers?
thanks
Check with Crane Cam's.
Old Oct 2, 2005 | 07:10 PM
will62085's Avatar
in the for sale section there are some jesel shaft mountes for sbc/lt1 for like $500
Old Oct 2, 2005 | 11:01 PM
DiabloGT's Avatar
http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem
would any of these work?
thanks
Old Oct 3, 2005 | 12:05 AM
will62085's Avatar
those would work, but i dont think you can use a center bolt valve cover with them
Old Oct 3, 2005 | 01:33 PM
DiabloGT's Avatar
can i still use otvc? and what covers would fit afr 227 heads that are not centerbolt?
Old Oct 3, 2005 | 01:36 PM
Jesel makes an "economy" shaft rocker setup for about $650. But the people who tried them (K Mook was one) didn't like them.
Old Oct 3, 2005 | 01:59 PM
DiabloGT's Avatar
i tried the jesel site and i cant find a place where to buy them though? and what were his complaints? oh ya and crane doesnt make any for who said to try them, so im not sure what to still buy yet thats not too much?
Old Oct 3, 2005 | 02:14 PM
WS6T3RROR's Avatar
http://www.sdpc2000.com/catalog/4122...ocker-Arms.htm
scroggins dickey sells jessel ss series shaft mounts, i have no experience with them so i cant really recommend them. if you know what part number you need with the 227's sdpc probably sells it even if it isnt listed just use the search function, or call em.
Old Oct 3, 2005 | 04:06 PM
Do a search on "Jesel" or on user name "kmook". I know he had some problems with them, but it was a couple years ago and I can't remember specifically. He doesn't seem to post much any more.
Old Oct 3, 2005 | 04:13 PM
Dave69Z's Avatar
AFR 227s have a 60/40 valve spacing and require a specific P/N for them. You can not use the SS series Jesels. Have to use the next step up, some T&Ds or some Crowers.
Dave
Old Oct 3, 2005 | 05:16 PM
1racerdude's Avatar
Ya can also use stud mounted RR's. They will sit at an angle to the head like a TFS head on a Ford.
Old Oct 3, 2005 | 05:17 PM
DiabloGT's Avatar
so arent normal ones stud mounted?
Old Oct 3, 2005 | 05:20 PM
1racerdude's Avatar
Yes
Old Oct 3, 2005 | 05:51 PM
Dave69Z's Avatar
From what I understand if you want to use a stud mount your best choices is to buy some .150 offset Isky's. $200 for a set of 8 .150 offset and $200 for set of 8 standard.
Dave
