changing rod bearings while motor is in the car?
Old Aug 17, 2005 | 01:03 AM
blackztpi's Avatar
i was wondering how hard that would be. i've got a very light knock. not sure what it is, but i want to find out how hard that would be to do if i had to.
Old Aug 17, 2005 | 04:47 AM
rskrause's Avatar
Moderator
Re: changing rod bearings while motor is in the car?
It's certainly been done. I don't know of anyone with a 4th gen who has done it though. A lift and air tools make this job, like any big job, a lot easier but even more so 'cause a lot of the work is in awkward position. Pulling the motor isn't that bad and has a big plus: you can inspect everything else easily. I am not sure I would feel comfortable without tearing down the whole motor, unless I were going for a really "ghetto" repair job for some reason.
Rich
Old Aug 17, 2005 | 10:35 AM
blackztpi's Avatar
well, the motor is still saveable if it is in fact a rod knock. it runs and pulls smoothly. i'm kind of doubting its rod knock, but i'm running out of options, so i have to be open.
Old Aug 17, 2005 | 11:15 AM
Digital Designs's Avatar
I have done this with my 94' B4C. It took a total of 8 hours from beginning to start up. I did have to wrap a chain around my strut tower brace and secure it to the engine to keep it held up and level. It is relatively easy to do. any questions pm me
Old Aug 17, 2005 | 12:26 PM
jay_lt4's Avatar
if your rods are knocking putting new bearings on a damaged crank isnt going to solve anything, just a waste of time
Old Aug 17, 2005 | 12:49 PM
Kurt Crosbie's Avatar
Exactly my sentiments
Old Aug 17, 2005 | 01:41 PM
blackztpi's Avatar
having hardly any noise and hardly any miles would leave me to bleieve the carnk has not been destroyed
Old Aug 17, 2005 | 02:23 PM
Jameslt1TA's Avatar
Either way i would recommend a rebuild...might cost a bit more but hey, might as well do it right the first time. I would use forged rods and pistons also.
Old Aug 17, 2005 | 02:30 PM
blackztpi's Avatar
umm, this is my new forged 355 we're talking about. well, it's not new. i purhcased it from a friend...it has roughly 2000 miles.
Old Aug 17, 2005 | 11:00 PM
white/blackss's Avatar
if it`s knocking, no matter how minor you need to have the crank polished.
most likely you will have to recon. the crank and rods though, good luck.
are you sure it`s not piston slap?
Old Aug 17, 2005 | 11:33 PM
blackztpi's Avatar
i wouldn't think it's piston slap. it doesn't change with temperature, as piston slap does. i wouldn't think i'd be hitting valves with pistons. i have JE pistons, 11.4:1 and a .603 inch cam. the je valve reliefs are much deeper than stock so that shouldn't be an issue. i had .005" piston to wall clearance so it should not be permanent slap.
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
