changing motor mounts, big job??
Old Jul 15, 2003 | 02:53 PM
Hawk's Avatar
just wondering if i have to drop the tranny or disconnect my exhaust to do this??? I'm hoping i can lift the motor with a jack and get away with it.............
Old Jul 15, 2003 | 03:01 PM
NVetro's Avatar
I would like to know also.
Old Jul 15, 2003 | 03:04 PM
mineralwater's Avatar
the hardest part of the job for me, was drilling out the rivets off of the old motormounts.
Otherwise, it was pretty straightfoward. Just make sure you do one side at a time - replace one side completely before you start on the other.
YOu just have to jack the motor up, pull off the "clamshell" housing. THen drill it open, replace it with the new mounts, then bolt the clamshell back in the way it was. After its all bolted up, adjust the motor height for the other side (so there's enough slack to pull the long bolt out all the way), and repeat.
Its a lot easier than it sounds. Its just time consuming
Old Jul 15, 2003 | 03:18 PM
Hawk's Avatar
sounds good, anyone know of any part #'s for a solid mount?? Prob gonna buy a pair, but just install one solid mount on the passanger side of the engine, leave the driver side stock. I'm doing this because my engine bangin the hell out of my pass collector. Thanks
Old Jul 15, 2003 | 03:28 PM
Hawk's Avatar
http://store.summitracing.com/defaul...635+&x=15&y=15
found those,
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
guionM
18
Jul 11, 2002 01:45 AM
