Changing headers
Old Apr 28, 2006 | 02:51 PM
Doors's Avatar
Changing headers
Finally bought some pacesetter shorty heads for my 97 Lt1, Is there anything else u guys would recommened changing while installing the headers? I was thinking of new motor mounts, where can I get a good pair? anything else? thanks
Old Apr 28, 2006 | 05:40 PM
sko_spo's Avatar
Re: Changing headers
Make sure to install some new spark pugs and wires while your down there. I recommend the NGK Iridiums plugs and Taylor 8mm wires . But as far as new motor mounts? Im not too sure, depends on how many miles you have on them . When i did my longtube Jet Hots, I had a real pain getting in the driver side one so i removed my motor mount, but it was complety fine with only 49000 miles .
Old Apr 29, 2006 | 08:25 AM
2000GTP's Avatar
While you have the old exhaust out, it would definitely be easier to swap the motor mounts. A poly replacement would be a good choice. I bought the poly Prothane motor mounts and they ran under 50 bucks. You can get them at Summit, Jegs, or most of our Supporting Vendors. Plugs and wires as mentioned above isa good idea. Granted Pacesetter does supply a set of bolts and header gaskets that do a adequate job, it would probably be wise to upgrade to a better set of gaskets and locking header bolts.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
birdblack
Dec 30, 2014 06:59 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
