changing firing order makes power???
Old Feb 3, 2006 | 10:50 AM
  #16
Tricked-Out-Toy's Avatar
Re: changing firing order makes power???
I see what your saying there, but I was reading on a impala board that someone was leaving the injectors wired like they were stock and those cylinders that were changed would just act like the old batch firing system. I know the tpi's were all set up that way and some early lt1's had it to. there should be any issues with the o2 sensor when its set up like this. I would think more fuel would be used in those sylinders but other than that the pcm would compensate for it being set up in a batch sequence.
Old Feb 3, 2006 | 11:20 AM
  #17
1racerdude's Avatar
Ya won't see 8-10FWHP on the normal LT1. What Darrin is refering to is a 8-10 gain on a 1000+HP pro motor.
If ya got a 500+FWHP engine ya will see small gains but it is NOT an automatic 8-10 HP just with a cam change and a 4/7 swap.
IMO it's NOT worth the trouble or expense to change.
Old Feb 3, 2006 | 11:43 AM
  #18
Might want to try your "search" again on "Advanced Tech". Both the benefits of changing the firing order and the difference in sound caused by firing order have been discussed in posts there.
Old Feb 3, 2006 | 11:50 AM
  #19
sorry, I thought I did a site search not just a LT1 search. thanks for the heads up.
Old Feb 3, 2006 | 11:54 AM
  #20
Sometimes the "search" feature hiccups. It isn't unusual to enter the data in the "search" fields, hit the button and get an immediate "no matches". Smiply step "back" to the search screen, and hit the button again.
Old Feb 3, 2006 | 11:58 AM
  #21
I just did a search on "firing order" on Advanced Tech only. Got 41 threads, several covering the 4/7 swap and others dealing with why engines sound different.
When searching, don't forget to change the "find posts from" field to "any date".
Old Feb 3, 2006 | 12:23 PM
  #22
ya I went right over to advance tech and have been reading since you posted last. good stuff, thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
smokin25th
Jan 1, 2015 09:06 AM
