changing the fan temp
Old Nov 30, 2010 | 06:18 PM
94Z28LS1toLT1's Avatar
hey everybody i would like to know how i can change my temp settings for the fan, i do not want them running at stock anymore. i would like to have it so where the temp doesnt go pass the middle. but i would like to kno if i dont run stock temp of the fans would that affect my car or if it will run bad. i heard if u run it cooler it runs faster. thank u anybody with any info on my thread.
Old Nov 30, 2010 | 06:32 PM
RamAir95TA's Avatar
Re: changing the fan temp
It would be best to install a lower temperature thermostat (160 is most popular) and have the PCM reprogrammed (I suggest www.pcmforless.com) to turn the fans on at a lower temperature.
Old Nov 30, 2010 | 07:02 PM
96 Z 28's Avatar
That's the compete answer!!!
But as an FYI, you can run a 160 Deg Thermostat alone, and they temps will rarely climb higher than 1/2 way. I did this for 2 years without any issues.
My PCM Reprogrammed + 160 Deg Thermo, and this past summer the temps sat at 1/3 in 100 Deg Heat & 5 MPH Traffic... So worth reprogramming, but not JUST for the fan settings
Old Nov 30, 2010 | 07:30 PM
cool thank u guys, what did u guys have to do to reprogram your fans, i called keith on the website and left a message for him. i went to the website and was a little confused on what to click on to get me to the part to reprogram the fans. and i am running a 160 tstat in my car brothers
Magenta_Hearts
Mar 29, 2017 08:54 PM
HCz28
Feb 15, 2015 03:01 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jul 4, 2005 05:00 PM
