changing #2 plug for lt1 4gen firebird/camaro
Old Aug 8, 2004 | 02:42 PM
wesley jones's Avatar
Unhappy changing #2 plug for lt1 4gen firebird/camaro
How do you change the spark plug for #2 under the alt and by the air compresser. I cannot see the plug or wire from below .there must be a way
Old Aug 8, 2004 | 03:51 PM
Lyle A's Avatar
Re: changing #2 plug for lt1 4gen firebird/camaro
Take the alternator off and squeez your hand in there if you can. Some take the motor mount loose on that side and jack up the engine for more room.
Old Aug 8, 2004 | 06:08 PM
chrism400's Avatar
I also got it by removing the alternator. Place a piece of carpet over the engine, and lay across it with your feet hanging over the driver side. Wedge your arm in and you should b e able to get to it. It's a pain! My friend Scott is a master mechanic and that is how he does it. His arms are pretty big too but he can still get it in there.
Old Aug 8, 2004 | 06:51 PM
RE AND CHERYL's Avatar
An easier way is to cut the right front corner off the car.
I removed the alternator, it was a bit easier.
Old Aug 8, 2004 | 07:39 PM
Talking Re: changing #2 plug for lt1 4gen firebird/camaro
I tried the method of laying across the engine and removed the alt. squeezed my big hand and finally got the plug out. only came out of it with one scrape i can live with that thanks guys well done
Old Aug 8, 2004 | 08:26 PM
Heatmaker's Avatar
Advanced Member
Sparkplug Kama Sutra my friend...
Old Aug 8, 2004 | 10:37 PM
Lyle A's Avatar
You must become one with the machine!
Old Aug 8, 2004 | 11:13 PM
Buttercup's Avatar
Once one learns to work by feel instead of sight, these cars become 100% easier to work on
Old Aug 9, 2004 | 01:28 AM
kingman109's Avatar
ha- it took me 4 hours to get- dropped my y -piped and wove my arm through headers to get to it- had arm up to shoulder to reach with a friend on top telling me left or right- eventually got it but man it was a pain- good luck
Old Aug 9, 2004 | 09:30 AM
chrism400's Avatar
Good job Wes! Now just wait until you replace your spark plug wires!!!!!!!!
Old Aug 9, 2004 | 09:46 AM
GREGG 97Z's Avatar
Removing the AIR and the A/C system makes it much easier to access that plug. Come to think of it, removing those things makes everything much easier to work on on the passenger side.
Old Aug 9, 2004 | 11:13 AM
OutsiderIROC-Z's Avatar
Boy your correct about that. I changed the plugs on my 95 Z28 on Friday. What a PITA!!!!!!!
Old Aug 9, 2004 | 12:23 PM
Z28SORR's Avatar
I found the #8 to be the hardest on my 97. But then I didn't drop the "Y" pipe.
Highlander
Jan 12, 2020 02:13 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
David Dorris
Jan 17, 2015 08:10 PM
Jul 4, 2005 05:00 PM
