Changed head gasket and now its not starting HELP!!! Newbie...
Old Sep 27, 2006 | 08:38 PM
rap1404's Avatar
Ok guys the starter seems to be free spinning and the engine now holding any pressure and it backfires sometimes after trying to crank. could it be the adjustment of the vaves/rocker arms?
thanks in advance
Old Sep 27, 2006 | 09:34 PM
Kyle@CSS's Avatar
Re: Changed head gasket and now its not starting HELP!!! Newbie...
Sounds like it could be the valves. How did you adjust them?
Old Sep 27, 2006 | 10:29 PM
rap1404's Avatar
Just by turning the crank from toop dead center and adjusting by feeling the stiffness but i probably overtighten it therefore im not getting compression. its supposed to be 3/4 of a turn after all play is removed at the pushrod?
Old Sep 28, 2006 | 12:08 AM
oneslowz28's Avatar
read this and readjust the valves. http://shbox.com/1/4th_gen_tech2.html#adjust_valves
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
