Change Optispark, now leaking
Old Apr 29, 2004 | 09:48 PM
  #16
Originally posted by 96redformula7
wait a minute, I would think you would use a block of wood Bigget than the seal!?!?! Aren't I going to lay the wood flat over the metal part of the seal and tap it in straight?? I would think if it is smaller I would damage the rubber??
I am definatly going to have to paypal you for your help.
Sorry, I may have not been clear. I did not mean a block of wood same or smaller only a pipe. The wood should be any size larger to cover the whole seal.
Old Apr 29, 2004 | 10:49 PM
  #17
96redformula7's Avatar
I really appreciate the help shoebox. I am going to be doing it Saterday so I will let you know how it goes. Can you email me you paypal information so that I can be sure to let you know I appreciate your help. My email is mfranco3@elp.rr.com. I am going to wait to see how it goes saturday then I will let you know or send you some thanks.
Old Apr 29, 2004 | 10:52 PM
  #18
Have you never been to my Tech Page? There is a donate button on the bottom.
Old Apr 29, 2004 | 11:15 PM
  #19
I have been their and used it tons of times, never seem the donate button though.
Old Apr 29, 2004 | 11:23 PM
  #20
I guess I need to move it to a more conspicuous spot.
Old Apr 30, 2004 | 01:38 AM
  #21
Bersaglieri's Avatar
I just changed my opti today..and no opti seal anywhere....is this only on vented models? Cause I have a 94...I dono, I figure if GM didnt put one on, it shouldnt be there.
-Dustin-
Old Apr 30, 2004 | 08:14 AM
  #22
-Dustin-
A 1994 has the splined drive for the opti. There is a smaller seal in the timing cover for the drive.
Old Apr 30, 2004 | 01:53 PM
  #23
Ok, thanks just making sure, cause I dont want to do that again for awhile.
-Dustin-
Old May 1, 2004 | 12:10 PM
  #24
Seal won't come off. I am trying to use a screw driver.
Old May 30, 2004 | 12:51 PM
  #25
j071752's Avatar
What was leaking? Oil or water
Shoebox, anyone,
I was reading this post since I have a water leak that appears to be comming from just above the opti, a steady drip, it is not comming from the small hole at the bottom of the water pump, is that the weep hole? it is not comming from any hose attached to the water pump. It seems to be comming from behind the water pump or between the water pump and block, a steady stream that does not start till the engine is at about 180 degrees+. It looks like I am going to need to pull the water pump to find out what this is. From looking at a picture of the back of a pump, it could be comming from the shaft, but not t hole at the bottom. It doesnt seem to be comming from the gaskets between the pump and block. Any troubleshooting advice guys? Thanks!! Jim
Old May 30, 2004 | 12:57 PM
  #26
Re: What was leaking? Oil or water
Originally posted by j071752
Shoebox, anyone,
May not be coming out the weep hole for some reason, but still sounds like the pump.
Old Jun 16, 2004 | 03:30 PM
  #27
j071752's Avatar
Sure was the pump
It was the pump, thanks, leaking right out the shaft on the back. I went ahead and ordered the Opti seal discussed above and the #10457293 Cap Kit from GMParts Direct $108.45 plus $21.69 shipping, figured even though I have no miss with 108,000+ miles she is due. The water pump #12527741 was $138.67 plus $27.73 shipping in case anyone needs that info for reference. Gonna get on the reinstall this weekend, I have a couple of questions if someone can answer them:
Should I use black RTV or some sealer on the water pump gaskets?
Is there anyother way to break the crankshaft pully bolts loose other than buying a tool to fit in the holes on the front side?
I also have the dreaded intake leak, when I fix that later on will I have to drain the coolant again?
Thanks, Jim
PCLZ28
Dec 24, 2015 05:19 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
