CCV Valve & PCV Valve
Old Jan 31, 2004 | 01:13 PM
Don't Look Back's Avatar
What's the function difference of these two components? I know the PCV is Positive Crankcase Ventilation, but I've never heard of a CCV valve. I replaced the CCV Valve with a PCV valve, under the assumption that it was the PCV valve.
Thanks, Keith
Old Jan 31, 2004 | 02:29 PM
Kain's Avatar
I've never heard of the CCV, or at least it under that name. What is it?
The PCV valve is the line that runs under your throttle body to the driver side, its that big metal line.
Old Jan 31, 2004 | 02:56 PM
The CCV valve goes from the passenger side valve cover to the passenger side of the throttle body. I'm assuming its Crank Case Ventilation, but I thought the PCV valve did that.
Old Jan 31, 2004 | 03:16 PM
Kain's Avatar
Thats what I thought you were talking about. I took mine off, capped the plug on the TB with a vacuum cap, and put a air filter breather on the valve cover.
Old Feb 1, 2004 | 01:12 AM
The only thing that is located in that hose is an empty 90deg plastic elbow that connects the hose to the valve cover. There is no "valve". That hose supplies filtered, MAF measured air from a port in front of the throttle body blades, flowing to the valve cover. From there, the air is pulled through the crankcase and the lifter valley, and out the PCV valve. Removing the passenger side line accomplishes nothing (unless excessive blowby is loading up your TB with oil), and "opens up" what is supposed to be a "closed" system - in effect, creates a vacuum leak. Nothing that the long term fuel corrections can't overcome, but I have never understood why people feel they have to install "breathers".
Old Feb 1, 2004 | 07:00 AM
97FormulaWS-6's Avatar
CCV, could you mean CCPV? Carbon-Canister-Purge-Valve?
that's a small black box on the PS of the intake manifold, with about 3 lines hooked up to it... that vents the Carbon-Canister on the PS of the car...
14
Aug 11, 2015 12:03 PM
surreybrad
Aug 10, 2015 09:34 AM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
