cc503 vs. hot cam
Old Dec 30, 2009 | 08:52 AM
  #16
dangalla's Avatar
Originally Posted by VIPRETR
You're going to have to shift the CC306 much higher to see good gains, like 67-6800. I shifted my 'lil hotcam at 6400 for best results.
nobody is talking about a 306
i would also recommend upgrading springs with any cam upgrade, and never to lt4 springs. for the price of upgrading to a new 306 maybe you should seriously consider a custom spec'd cam.
and +1 for the convertor, that should be a big concern for you right now
Old Dec 30, 2009 | 09:53 AM
  #17
VIPRETR's Avatar
Can you read? Did you even see the quote that came before my sentence about the CC306? If you can't keep up with the thread, stay out of it. People wonder why the guys with experience aren't around anymore. This is a perfect example.
Larry
Old Dec 30, 2009 | 05:07 PM
  #18
meissen's Avatar
Are you sure you meant 2000 converter? I thought the stock LT1 converter was larger than that...
Regardless, contrary to Jake Jr's rant about bigger not being better, it's a proven fact that the CC503 vs LT4 Hot Cam is going to have the CC503 making 10-15hp more. IN THIS CASE bigger is better comparing the two CC503 and LT4 hot cam.
Old Dec 30, 2009 | 08:45 PM
  #19
Z-RATED94's Avatar
Originally Posted by maybe2fast
not going to get us started on the lighter LT4 valves are we?
Why, do you think that (lighter valves) has nothing to do with proper valve control? Please give us your thoughts on valvetrain control. Can they also handle slightly larger valves too, say 2.00 & 1.54s?
Old Dec 30, 2009 | 08:54 PM
  #20
bw_hunter's Avatar
I suspect his comment had more to do with the age old debate on thre springs used with the LT4 hot cam kit. Being designed for the LT4 engine, which has lighter and larger valves, many people think they are marginal when installed in an LT1 or ZZ4 engine. I happen to agree with the logic but, as was mentioned before, there are tons of examples out there that work just fine....
Old Dec 31, 2009 | 06:50 AM
  #21
dangalla's Avatar
Larry
the thread is about the hot cam vs a 503, at no point in time does anyone mention the 306. his quote is referring to the difference in rpm from a hot cam to a 503, if anyone is not coming back its because of people like you larry. stay on topic and pay attention
Old Dec 31, 2009 | 01:48 PM
  #22
marshall93z's Avatar
Originally Posted by JAKEJR
The internet is LOADED with BAD and INACCURATE/INCORRECT informatinon so you have to be REALLY selective in what you believe and what you don't.
Funny that you mention this! I couldn't agree more.
Old Dec 31, 2009 | 02:25 PM
  #23
VIPRETR's Avatar
OK, apparently you can't read. Here is the post in this thread I was replying to...
Originally Posted by bkpliskin
I agree. While I initially opted for the 306 back in the late winter/early spring of this year for it's bigger duration and higher lift... I ended up really wanting to gain up top for a couple of reasons. My car will be at the track, but it will be street driven 99.9999% of the time. The car already had too much low end power for the street. Couldn't hook to save my life. The top end power gains were in the back of my mind because I needed to gain more on the top end to keep up with the modded LSX's and the forced induction cars. The 306 was going to give me enough of a low end gain but the 4k+ rpm gain was the biggest thing. The 3200 stall takes away any shortcomings in the low end department. Only thing I'm wondering about it reving to 6300 on my stock bottom end.
Sorry to sidetrack the thread gentlemen. On the original subject I would run the CC503 with PAC 1518 springs. It has a minimal increase in harshness for a good bump in power. Thanks,
Larry
Old Dec 31, 2009 | 03:22 PM
  #24
Z-RATED94's Avatar
Or they THINK everything is working just fine. Personally I'd like to see a higher quality spring being used, such as yourself.
Old Dec 31, 2009 | 05:50 PM
  #25
bkpliskin's Avatar
Actually, when recommending additional bolt-on's to compliment a 503, I made a comment about my 306 and the stall speed I used for it. He then quoted my comment and made another comment about my 306. This all goes back to the original discussion and was quite relevant to the OP's question.
Old Jan 1, 2010 | 08:23 PM
  #26
Dwarf Killer's Avatar
Originally Posted by 84zed
Looking at installing my hot cam and mildly ported stock heads over the winter,
but I have heard so many people say they had wished they had gone for a larger cam.I am not looking to build a race car,but would like the best results.The car
weighs 3750 lbs w/driver,a 3.42 gear and a 2000 stall converter and full exhaust.
I was just thinking about selling the hot cam and buying the cc503 but was wondering if it was worth it.Also emissions is a factor.Thanks
503 is a much better cam. The springs won't be an issue under 5800rpm because this is a low-lift 503/510@.050 cam. You will need a 2400+ stall. You can pass ON emissions with it running stock compression. Is it worth selling the h-cam for the 503? If it were me I wouldn't bother, but I already have the 503 so I can blow away all you dummies who bought hotcams.
Old Jan 1, 2010 | 08:31 PM
  #27
Looks like another thread becoming a candidate for "closure"........
Old Jan 2, 2010 | 07:57 AM
  #28
RobsWS6's Avatar
I think everyone will agree that the hot cam springs are inadequate..even for the hot cam....
There seems to be quite a few people that never had a problem with the springs. Having said that, I didn't run them.
I bought the kit from Dal back in 97. I gave the springs to my buddy that worked at a machine shop to check them out. There was no way I was running those springs and sent them back, also sent the rockers back for some Crane Gold's. I posted what we had found on the f-body list back then and nobody could believe that GM would sell springs that were barely capable of the lifts of the HOT cam.
I'm still running the HOT cam and Crane springs to this day without any problems
Old Jan 2, 2010 | 12:48 PM
  #29
matLT1's Avatar
This has been discussed so many times. The fact is you need to understand what your application is and what you expect to get out of the car. IMO you need to talk with COMP's tech line to get an accurate answer.
Old Jan 4, 2010 | 08:15 AM
  #30
wrd1972's Avatar
If I had to do it all over again, I MIGHT re-sleeve (the guides) on my LT1 heads to use the thinner LS1 valves ASSUMING it was not an arm and a leg to do. Something just bothers me about hollow valves. I already machined my existing guides down to 1/2" so I can use any valve spring combo under the sun.
