CC466 - Passed California Smog
Old Oct 4, 2008 | 07:36 PM
Wild1's Avatar
For those who are interested if the cam can pass smog... Yes!
CCA-07-466-8 => Comp Cams XFI
218 224 .570 .565 113°
Before: Stock Heads & Cam (Headers, Cat Back, CAI, TB bypass)
............%CO2...%O2...HC (PPM)....CO%....NOx (PPM)
15 MPH...15.1......0.2......10...........0.01.....370
25 MPH...15.0......0.2......14...........0.01.....482
After: CC 502 Cam & Heavy ported heads w/2.02 valves & Serdi 5-Angle valve job
............%CO2....%O2...HC (PPM)...CO%....NOx (PPM)
15 MPH...14.0......0.5.......16..........0.04.....219
25 MPH...13.9......0.6.......34..........0.13.....352
The heads were ported/polished and new seats installed at Superior Auto in Anaheim.
The computer programming was done at Haddad Motorsports in Irwindale by Tad.
Get this environmental cam and cut your NOx today!
95 Z28/1LE - T56
Induction - SLP CAI, K&N dual air filters, RK Sport Air Foil, TB Bypass, 1.6 RRs Pro Magnum, Manley Pushrods
Exhaust - Edelbrock Ceramic Coated TES Headers, Off Road Pipe, Ex. Insert Cone, Edelbrock Cat Back
Ignition - Jacob's Ultra Pack Ignition, Coil, Trigger, 8.5mm Plug Wires, Bosch +4 Plugs
Drivetrain - Hurst Short Throw Shifter, SLP Alum Driveshaft, LG Torque Arm, GM 4.10s with Eaton Posi, SLP Lightened Flywheel and HP Clutch Package
Cosmetic - RK Sport Back, ported heat extractors
Suspension - Hotchkis Front Springs, Welded Sub-Frame Connectors, Hotchkis Lower Control Arms, Hotchkis Strut Tower Brace, RK Sport LCA relocation brackets, Rear weight jacks by Ground-Control with Eibach 175# springs, and Spohn Adjustable Panhard Rod, Bump Steer Tie Rod Ends by Baer, 285/50R17 Goodyear D1-GS D3s, custom powder coated 17" wheels
Old Oct 5, 2008 | 01:24 AM
brianswimmer23's Avatar
awesome info thanks!!!
Old Oct 5, 2008 | 09:15 AM
SS MPSTR's Avatar
good information to add to the list of cams that have passed.
now if I could only get mine to pass
David Dempsey
Mar 12, 2016 12:42 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
