CC306 Rev Limiter???
Old Nov 8, 2007 | 08:40 PM
95 Civic's Avatar
Im installing the CC306 in my stock bottom end motor. Has 1.6 Roller rockers, Hardened pushrods, valve springs, TH350... etc.
What should I set my Rev limiter at???
Also, I will be stock heads for now...
One more question... Do you recommend PCMforLess???
If not, who?
thanks
Old Nov 8, 2007 | 09:40 PM
RyanD's Avatar
i rev mine to 6500
Old Nov 9, 2007 | 12:55 AM
SoloExceptional's Avatar
Mine is 6800 I heard the cam can pull to 6700 not sure though maybe someone can confirm this. What kinda springs are you using? I went for a MadZ28 tune myself. I'm sure they'll both work either way, but since you're running stock heads I think the motor is gonna starve up top. I'm not really an engine guru so I can't tell you for sure.
Old Nov 9, 2007 | 06:27 AM
93v8clone's Avatar
mine was at 6800 till i nitrous nuked it oh well it will pull till bout 6500 on stock heads then run out pcmforless did my tune hit it about dead on just be very specifac when u tell him what ya want
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
