cc306 questions
i just installed a the cc306 in my 93 trans am with all the supporting mods (behives,magnum pushrods,magnum rollers,seats,retainers, melling pump with gm white spring)
wondering what i should shift at i searched and found that 6500 is a good shift point curious though how long other peoples engines have lasted revving that high my engine only has 33k on it and i use synthetic oil just looking for some feedback and what other people have experienced with the cam
i shifted mine at 6800...but i only ran 11.90/12.0 on motor...with stock heads and bottom end...
that cam will peak around 6400 with stock cubic inches...youll need to shift at least 6500...prolly 6600-6700...mine lasted over 15k miles spinning it that high...my motor had about 10k on it when i cammed it...
The issue is not the block itself the issue is the rotating assembly the bearings in particular and they most certainly can have problems is revved too high.
As said some are luckier than others, last year I lost a shortblock to bearings, put in a mild cam at 65K and then the current heads and cam at 95K and blew about 101-102K, I had not take the precaution of using a white spring though and I have since been enlightened a little. Someone suggested that stock springs with 10 years and untold number of heat cycles can get weak and not deliver proper pressure which is the real reason to consider a white spring, more because it is a new piece rather than the pressure increase.
Current motor has fourty someodd thousand miles on it, the last several thousand with this heads and cam, I did put a white spring in it and no sparkly oil yet, no idea how long it will or wont last.
I keep my motor below 6500 even during the shifts.
-Dustin-
The stock bottom end is a mystery....there is no real consistant result after 6k...some people swear 6500 RPMs does nothing to it, others worship the idea not to rev past 6100 - 6200. My theory is unless your are THAT confident in your bottom end and how its been cared for, dont spin past 6200. If that wont due for you and the setup you want, then i would recommend you build your bottom end with quality parts that can take the abuse, and then spin as high as you want (or as high as you built it for). This way, there is no questioning yourself or the structure of the setup, and you should be able to drive it like you want to.
just my 2cents
just my 2cents
CC306 and ported heads here. Cam went in at about 75k miles, heads went on at 90k. Currently at 95k and just added a 100 shot so we'll see how it lasts now. Cam only i shifted at 6300ish, shifting at 6700 with the heads, and 6000 on the juice.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
