cc306 powerband
Old Nov 8, 2006 | 10:48 PM
96ZCamaro's Avatar
cc306 powerband
You guys with the cc306 cam. How high do you rev up to and when does the power start to drop. I needed to know because I am going to be sending in my computer to get it tuned and need to know where I should set the rev limiter at.
Old Nov 8, 2006 | 10:52 PM
MeanGreen97Z's Avatar
Some have posted about shifting at 6400. I would push the rev limiter up above 6800 and use the dyno to determine my shift point.
Old Nov 9, 2006 | 09:03 AM
jsetzer's Avatar
^^ Ditto. Usually @ 6500 is a good shift point, but check it to be for sure.
Old Nov 9, 2006 | 09:52 AM
Z-RATED94's Avatar
The best way would be to put it on the dyno, find where it peaks at, and shift about 300 rpm after that. As far as how much more the limiter should be set above that I don't know.
Old Nov 10, 2006 | 08:36 AM
93yellowta's Avatar
depends on how long you want your bottom end to last. if your stock, then personally I wouldn't shift over 6300-6400 rpm's. I know the 306 cam likes to rev. higher but I would be cautious unless your ready to build a better bottom end. I have mine set at 6200 rpm's. just because I have 160,000 on my stock bottom, but I also put in the cam/heads and most other mods on my engine at 150,000. so far a great 10,000 miles on a high mileage motor. I would be willing to bet if I set my rev. limiter higher like around 6400 or higher I would of spun a bearing or something else by now.
Old Nov 10, 2006 | 08:43 AM
Daniel6718's Avatar
i shift at 6800 for a while, tuned it down for n20, shifts at 6500 now, also run 11.9x with just a cam, stock heads....
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
