CC306 help please
CC306 help please
Guys. Everyone talks about this cam. Comparisons to the XE cams and such make locating the XE cams easy...but everyone calls this cam, CC306.
Far as I can tell, no one sells it as the CC306. What's the part #, grind #, or how to I identify the CC306 when browsing say Jegs or Summit?
I want #s on this cam so I can compare it around a little better. Right now, eye is on XE 236/242; or Comps 290HR-12 which is 230/244.
Thanks for the help.
DJ
DJ
If you turn to the "TPI-LT1,LS1 section of summit and look at the cams. You will noitce that the number for the "CC306" will be 07-306-1074 or something. I just ordered mine recently. Specs are in the catalog. Try a search on this board that usually helps. have fun!!!~~rob
LOL...while I couldn't find any cams under TPI/LT1/LS1 except Lunati LS1 cams.
I FINALLY found online the CC306 specs.
Seems the Comp 290HR-12 is the CC306; 230/244 duration .510"in .540"ex @ .050" 112* LSA
Cam looks good on Desktop Dyno!
DJ
DJ
